I have a 1993 24' Chaparral with a 5.7l engine and a Volvo Penta Duo-prop outdrive (DP-C or DP-C1 not sure?). I have been having trouble with the tilt/trim. The unit goes down fine but will not go back up unless I jump power directly to the hydraulic motor. I have replaced all 4 of the relays (2 at the transom and 2 under the dash). There is an analog control unit (little black box) under the dash. Could this be causing the problem ? Is it common for this part to go bad ? I have seen other posting talking about an in-line fuse. Do I have one ? Where is it ?
