Volvo Penta Trim Cylinder Rebuild
etek14
2008 Volva Penta 3.0,
SX-A cylinders
Not sure of numbers, could be 3889954,3889956, 3889958 ?
Drive Info
SX-A, 1.97 ratio
388360320311982
Prod# 3883603
SN# 1202211719
Looking to rebuild units, replace seals, wipers are dry rotted
Any info , video, how to get C clip out to remove end cap without damaging unit. Also the proper rebuild kit, I see SX-A rebuilds but unsure if the correct ones
Nashville
SX-A cylinders
Drive Info
SX-A, 1.97 ratio
388360320311982
Prod# 3883603
SN# 1202211719
The different cylinder part numbers you list are for the three different trim position limits… full, 42-degrees and 32-degrees. Repair kits are the same. (FWIW. Sorry, the Serial No. isn’t correct; and no idea what the number above Product No. is. Is it possible to post a picture of the tag riveted to the drive?)
pfeff
I'm also interested in this. I just bought an entire kit off Ebay to replace my motor/lines/cylinders since my motor was shot, i figured i'd replace it all while i was in there. NOW i see there may be different cylinder numbers?
And here i thought i've researched this enough. mine is also a SX-A (1.97/Alt42).
this is what i bought, and finished installing it tonight. All seems to work well on the trailer. Cycled it about 10 times up/down.
