I repaired my tilt/trim because of a burst hose. I removed and replaced the upper gear <br />assembly to gain access the the external hoses that needed to be replaced. The tilt/trim<br />works fine now, but the LED indicator is out of sync with the position of the stern drive.<br />How do I adjust the LED readout?<br />This is a 1988 All Seas Marine Imperial 1900.<br />4.3l v6 AQ-205<br />Hydraulic trim.<br />DP-290 or DPA-230, not sure how to determine the difference.<br /><br />Thanks!
