Re: Volvo Penta SX-M bellows inspection on boat?
Where are you reading this gibberish ????????????
If you want to inspect the bellows, remove the outdrive. If no water is in the bellows, it's good. Just check your alignment, lube your ujoints, grease the splines with spline grease and rinstall the drive with a new ring around the water passage. The alignment and greasing the splines MUST be done at least yearly. Just part of owning an outdrive.
Don
Page 43 of the Volvo Penta SX..,DP-S service manual: U-joint and Exhaust Bellows Installation: "Coat outside surface of the gimble bearing bore with Volvo Penta Gasket Sealing Compound".
Here is the parts list Im working on:
TOOLS
1) Engine hoist with Eyelet ring or build a dolly for outdrive. Not sure about the dolly idea though.
2) 3 jaw hammer slide (OTC 1176 type)
3) My trusty U-joint removal C-Clamp with sockets to fit. Im goiung to try to avoid using my 3lb engineers hammer, which I usually use on U-joints.
4) Gimble install tool ( large socket or ?)
5) Gimble alignment tool
PARTS
1) Gimble bearing -Volvo
2) U-joints (2x) -Spicer if I can find them.
3) Drive Bellows (exhaust bellows looks great)
4) New lock nuts (6x) if not tight turning during install
5) Volvo Penta Gasket Sealing Compound
6) Gimble bearing grease
7) Volvo grease 828250 for pinion bearing carrier end and Ujoint bellow lip
8) Volvo sealing compund 1141570
9) Moly grease for splines
10) Motor oil for O-rings
Am I missing anything?
Is there a Volvo kit with all the required parts: Bellows & bearing etc.?
Just found this: Bellows kit (PN 3841481)
Im getting closer.
