I have a Volvo Penta 290 DP and I needed to change the bushings on the steering yoke shaft. I was able to pry the yoke and shaft down with a couple of large pry bars to remove it from the splined tiller arm. Now when I try to reinstall the steering shaft into the tiller arm it won't fit all the way into the tiller arm. It needs to go in (up) another 3/8" - 1/4" to allow the lower seal to contact the sealing surface on the transom shield. I'm hitting it with a dead blow hammer and it feels like it's seated but it's not. Can't figure out why the same two parts I removed won't go back together.
I got frustrated and took them both to the floor and beat the tiller arm completely down where it needs to go, and I had to literally and mercilessly beat it down to where it's supposed to sit. Then I had to use a puller to get it off. I tried freezing the steering yoke shaft and heating the tiller arm and the arm still didn't seat all the way down on the shaft (and again I had to use a puller to get them apart). Does anyone have some insight on what needs to happen? I mean it's a very simple take it out and put it back in situation. the splines and shaft are very clean and undamaged. I don't get it.
