Re: Volvo Penta power trim pump oil
Jim.. I had a boat with a Volvo 271 and 290 Duoprop outdrive - so not sure if its the same tilt/trim pump.<br /><br />Mine had a little screw-plug near the flat-top of the base. I would unscrew and fill almost to the top of the hole (allowing enough room to put the screw plug back in).<br /><br />Do you have a model# on the pump. I still have my old one, the diaphram went out on it, so it would not hold the oil. I bought a new pump, then later heard that I could replace the diaphram for about $15.. oh well.<br /><br />-David
