Volvo Penta Power Tilt Problem
aircom
Hello all
I am new to this site
I have a problem lowering my inbd outbd power tilt.
It is now stuck in the trim up postion. the relays do click when switch activated up or down but the motor does come on. This happened after bottom of boat sat in sand bar. the pump is a volvo penta 3860879. The 10 amp fuse at the pump is good.
The up and down relays tested ok with power to coil and the contacts
In dire need of a suggestion on what to do next.
Thank You
