Volvo penta outdrive replacement
jcsp
I HAVE A 1999 VOLVO PENTA 5.0 Gi PWTR INBOARD ENGINE WITH A DP - SM 1.95 OUTDRIVE, AND I WANT TO REPLACE THIS ONE (UPPER AND LOWER UNITS ONLY, NOT GIMBAL OR RAMS) WITH A DPS - B 1.95 OUTDRIVE, BUT NOT SURE IF THAT"S POSSIBLE OR NOT. ANY HELP WILL BE REALLY APPRECIATED. THANKS
welcome aboard.
why are you yelling? (caps lock)
pretty sure you would have to replace everything including transom shield as not much is shared between the drives.
jcsp
Sorry, I use to write most of the time in CAPS, (just more convenient than glasses).
Thanks for your help. I also did some research and decide to repair mine one more time. I am having a corrosion issue that it keeps coming back. I am going to give it a try one more time. Thanks for your time
