I have been trying to use muffs to pull in antifreeze to winterize my boat. When I put the muffs on with a hose running from the house spigot water flows through the engine and the engine does not over heat. When I put the end of the house in a bucket to pull the antifreeze, it does not pull the antifreeze out of the bucket.
I replaced the impeller and even removed the thermostat and it still will not pull from the bucket. I drained all the water out of the engine from every drain plug I could find then filled the engine with afreeze.
So why is the impeller not pulling the water or antifreeze from the bucket?
By the way, this is a VP 5.7Gi engine with a dpx outdrive.
thanks,
Pat
thanks,
Pat
