I have a 280 outdrive w/ mechanical lift, after replacing the safety switch,it goes up and down and the light@control switch goes out at full down position.
Should the light go out at full up position too? I'm afraid I'll damage something
if I don't release lever at the point drive hits rubber stop. From the switch location i can't see the outdrive at all as it comes up.Also, if I blow a fuse
on lift I could manually release the drive an lift it for trailering but I don't see a catch to hold the drive up.Any help would be greatly appreicated.
