greatvizier2003
- Aug 16, 2003
- 3
I have a Tanzer 26 sailboat with a VolvoPenta SailDrive. This is basically a shaft from VP fitted to a Honda 7.5 outboard and mounted inboard, in my case, under the cockpit. This boat has spent most of its life laid up, and the motor in consequence is in great shape. Replacing it would kill $6 grand. The problem is that it is manual start, and since the cord only mounts forward, starting from the cockpit (the way it was when I bought it) involved a jerry-rigged and complicated system that didn't work very well. So, I now start it from the cabin--fine if there are no distractions or you've got help on board. My question--what would it take to turn this to electric start? A starter unit and geared flywheel, obviously, but is it possible at all? What else would I have to do? And is there a place to get the parts I need used? A starter alone seems to be in the $250 range. I use this signature because I formerly lived on<br />GrandTurk
