volvo penta exhaust bellows
reel inn
I have a small pin hole in the exhaust bellows on my 280 outdrive is it neccessary to change that out? it is a bellows with a ck valve or flapper in it.
JB
Re: volvo penta exhaust bellows
Moving to I/O
f_inscreenname
It is just going to get worse. Anything on a boat broken should be fixed ASAP. Breaking down on the water is not fun. I just read a post from a guy that broke down out there. It took hours (with the help of the CG) to get towed to his ramp. The CG tried to get a commercial tower to do it first (big bucks) when they couldn't raise one they finally did it themselves. A 2am arrival time. I am not sure of any mechanical problems it will cause but a exhaust leak sounds like crap.
yoced
hmm - the problems with double posting...<br /><br />
Dunaruna <br />Petty Officer 2nd Class <br />Member # 22380 <br />posted May 09, 2004 06:49 <br />Hi Greg, <br /><br />The exhaust bellow on the 280 has a pin hole built in so that water drains out when the leg is raised, just make sure it is positioned at the lowest point (won't be effective if its at the top).<br /><br />Its normal, don't worry.<br /><br />Aldo
reel inn
Originally posted by yoced:<br /> hmm - the problems with double posting...<br /><br />
Cobra SX
If you didnt know now you do.<br /><br />Volvo penta/cobra<br />have little holes in the bellows to let water/exhaust gases flow from the water pumping sys.<br /><br />This is Toatlly a normal fuction on these models<br /><br />okay?
