Volvo Penta engine problems
dhatcher2002
Here is the run down, its a 83' bayliner w/ a 4cyl volvo penta, new Cap, rotor, plug wires, plugs, coil and points. Not started in about a year 1 -1/2. Runs great while in neutral, as soon as any load is on the engine, in gear, it dies. Any suggestions? I have thought about rebuilding the single barrel carb, BUT while in neutral its great, so...i dont think thats the problem. Also what is the firing order? I have it set up backwards right now, stupid I know but thats the only way it will run. 1-2-4-3 or something like that. What would cause it to run great with out load on the enigne but die as soon as engaged into gear? Thanks A BUNCH! Dan
Don S
Re: Volvo Penta engine problems
Timing being way off, carbs idle mixture being off, dwell being off, low compression, wrong idle speed could all cause your problem. Is the timing belt in good condition? Make sure everything is set to specs and in good condition.
You not only need the proper timing order, but you need to go in the right direction.
attachment.php
I could give you a link to the service manual, but would need to know the model number for your engine.
dhatcher2002
Dont have the money to put it in the shop. $50-60 bucks an hour for something I can do with a little help from other, kinda what forums are here for. I am going to take a look at that firing order again tonight and update! thanks for the advise guys! Dan
searay3
You really need to give that model number so you can get a manual. Your gonna need it....
Gary H NC
Thats for sure!! Don is our life saving engine and drive Guru!!!:D
dhatcher2002
PS - 270 outdrive 4cyl 2.1 Volvo-Penta
