I have a 2000 Volvo Penta DP-S mated to a 5.7GSi and have a question regarding some sort of drain hole on the lower unit of the drive. If you stand at the transom and look towards the bow, the drain hole is located on the left of the lower unit behind the water intakes. I have seen it on all of the Volvo drives (SX & DP). What is it and what does it do? The boat is out of the water currently and I noticed a small amount of oily ooze out of this hole that smells like drive oil. The fluid level in the drive is good and not cloudy. All of the mechanics I have talked to (both Volvo certified and not) don't have a straight answer. Some said it is an exhaust drain and the discharge is exhaust by-products. I am concerned. Any help? Thanks.
