mr. sandman
- Jan 31, 2011
- 12
I have a 2003 DP-G drive that is more than stubborn. I bought the boat last year and this has not been off the boat yet and I want to get it off, replace all the rubber and clamps and clean it up and repaint it. It has been a struggle but I have managed to get all the pins off except the port side hinge pin. Most were able to get off with heat, and some force and a lot of patience but this last one pin will not budge.
This has a stainless pin that is held in place by a set screw. I was able to get the set screw out but some of the threads were stripped but it is out. There is a "special tool" which looks like a small slide hammer used to float (drive) these pins out. Not powerful enough for this job.
On the starboard side, I was able to move the pin in a little using a small 3# sledge and short socket extension (which fits the pins' head well), once I moved it in a little I was able to pull it out using a 5# slide hammer. The port side will not budge. I even tried putting a propane torch to it and then tried moving it. No luck. I then rigged up a 1/2 SS bolt and was able to get a nut on the inside and put a lot of pulling force on it with a breaker bar and still no luck. I don't want to hit this with any more force as I am afraid I could brake the Aluminum Shield.
Any ideas on what to try next? Dynamite?
