DDAADDYY
- May 23, 2004
- 100
Last one guys, in swapping motors I've stumbled on the fact that I have BID ignition instead if a points condenser setup, presumably from as AQ271 or AQ311 that's OK without the ballast resistor, but I do have the wiring harness on the motor for an AQ260A/B the one (WITHOUT) the relay but my old harness for the AQ131D has the relay setup. I've done that invaluable test Don S posted on ignition/starting troubleshooters and everything is OK including turing the key. Starter/solenoid works fine when jumpering the posts 9.6v at coil when key power on and starts and runs fine when + wire from battery on coil. Question is what's the magical wire I'm missing to complete the loop? I have diagrams for both motors for electrical hook up and am at a loss. Or should I just wire in the relay loop from the AQ131D and be done with it?
As always thanks in advance for the tips and yeah prepping the motor took about 20 hours to fix heads and paint motor, 10 to prep transom, bilge, 10 more to swap motors 5 to rebuild carb after soaking for couple days, and so far about 10 to setup, completed installing the leg yesterday right on the verge of having her up and atem!! Great little project.
