Volvo Penta AQ131D Maybe Multiple issues
Veneyeth
I have a 26' V hull Home build boat with a Volvo AQ131D engine
Took it out was running what appeared to be fine but i May have multiple issues. The Tension Arm bracket went underway and overheated the engine. Blowing the seal on the Heat exchanger
I Took the exchanger back and refurbished it Dropped it back in the boat and didn't see any evidence of a blown head gasket. Brang it back but it would not come up to any decent RPM and had to drive it home around 2k RPM.
When I started troubleshooting at the dock I did a compression test to maybe rule out the head gasket and it reads 185-190 across all 4.
Plugs look good
Dwell was out about 10 degrees out so adjusted and timed it. (electronic ignition on order)
Timing is rock solid at 6 Degrees BTDC at idle and at 4200 RPM it is bouncing between 32 and 36. (spec says 32-36)
Sounds pretty good dockside maybe a little off at 4500 or so.
Take it out in gear WOT tops out at about 3500 and boat is up on a plane. (should i be getting the full 5k if i want it?)
Runs good for a half hour but is warming up to around 210 on the dial (checked with IR thermometer multiple places and cant find anything hotter than 190) (spare exaust manifold being blasted and rebuilt)
At the half hour mark i back the throttle down and cool it back down to 190 on the dial try and reaccellerate and it bogs down.
When i drop it out of gear and it accelerates smoothly
Have to return home yet again at about 2k
Back dockside under no load It was still good on timing / dwell but did sound worse off than cold/ normal operating temp when first going
Any thoughts?
jerryjerry05
Welcome.
Idling then revving under load you should be able to hit 45-6000 rpm's.
Sounds like the belt might be off by a tooth?
Veneyeth
Thanks
Ill have to check the belt again and make sure... But.
Went back to play with the engine a little this morning and engine didn't sound good. Sounded like carb, fuel, or fuel filter, pulled the carb to rebuild it and going to try to run on a spare tank with new gas. I was thinking back, and I think I may be using the wrong prop. About a year ago i married up the best parts of my original engine with a second one that I acquired. I may have put the wrong prop on the outdrive in the process.
Will update further progress when I next play with it but any suggestions would be appreciated
