Volvo penta aq131a high idle
awdurland
I replaced my points with a pertronix ignition and have an idle @ 1000 rpm right off the bat, my idle was about 500 cold and 750 hot before upgrade. I have the mix turned out 2 turns and the idle screw the same as per manual. I do not want to adjust my idle screw to compensate, any ideas?
awdurland
Re: Volvo penta aq131a high idle
also I checked my timing and set it @ 6 degrees BTDC, but it is @ 1000 rpm.
