MechanicDave
- Aug 17, 2012
- 3
So I think I scored a great deal but time will tell once i get into this engine on our new boat, little back story its my neihbors fualt that I got a boat, they loaned up theres for a vacation and we all got hooked. So I found this 1985 Bay Liner Capri 16.5' with a Volvo penta AQ125B/270 setup.
So first thing I started repairing is the switch board, Yeh bad idea adding light up switches... I wired the switches correctly but forgot about the bilge pump and how it takes 2 power inputs and when the float turned it on the power lead from the switch back tracked and grounded... LOL yeh i got a nice cloud of toxic smoke bellowing from under the dash. (lesson 1 learned)
Now lesson 2 I forgot the reverse pin was installed, and I found a tree under the water... I shelled the prop.
So I am hoping this is the few lessons that I needed to learn and no more bad stuff...
Ok next problem, the engine jumped upto 260 degrees. so I found there are a few leaks in the coolant system...
leak one the plastic elbow from the heat exchanger to the tube that runs to the sea water pump. LOL found no o-ring where there should have been one.
Then leak number two, coolant leak at the O-ring between the coolant tank and the heat exchanger.
these are the only leaks that i have found and it does not seem to me that it should be over heating from these 2 little leaks, I did pull the thermostat and test it on the stove, between 185, 189 degrees F. it opens right up, and leave it out for a moment and it closes tight...
SO what might I be missing, I will be replacing the O-rings and running a pressure test on the system in the morning and see if I have any other leaks but other experiance and wisdom is always welcome since I am new to this engine and the common problems it may have.
Also I gave $600.00 for it think I got a steal of a deal on it?
