Volvo penta 5.7L GSi 2000 Tachymeter stop working after about 10 minutes
cally725
My starbord tachtmeter stop working when the engine becomes hot afer about 10 minutes. The Sync meter needle then go to complete right of the meter, tach meter indicated 0. I tried swaping the tachs with the port one, but the problems stays on the starbord side.
Any idea ?
you lost a connection at the coil on the starboard motor. its the grey wire
cally725
Thanks, what kind of signal it is ? Can I use a DC multimeter to find where the signal is lost ? What kind of voltage should I get at idile ?
Its a pulsing signal. One pulse per cylinder firing, or 4 pulses per revolution.
However you should see the issue. Its either the cinnection at the coil, or its connection at main harness connector
