Stingray240CS
- Apr 27, 2008
- 7
I put my boat in dry storage and did not use it last summer so it has been sitting there for 2 years. It was working great last time I use it. Start every time as soon as I turn the ignition switch. This time, the engine start right away just like all other time but only last for 20 seconds. If I try to re-start the engine right away, it just crank but won't start. If I wait for a couple minute and try again then it almost wanted to start (run for a second or two). This is what I have done so far but still unsuccessful:
1) Replace the fuel with brand new 91 Octane fuel (I actually remove the fuel line from the boat tank and put it in a portable fuel tank with new fuel in it)
2) Replace fuel filter
3) Replace spark plug
4) Check to make sure that the safety lanyard is connected
5) Clean rotor cap and rotor
After all the above it still doesn't help with the problem so I removed the fuel injector portion (on top of the carburetor under flame arrestor) and clean everything. The fuel seem to spray a little better (more evenly) when I crank the engine and it seem to make the engine getting closer to starting but still only last for a few seconds and dies. I do hear a high pitch sound from the fuel pump (the one closer to the centerline of the engine, i assume it is the high pressure one) and is on when the ignition switch is first turn on ( I am assuming that the pump is priming the engine) but it stay on when the engine is running ( the 10-20 seconds that it actually run). Does anyone think it is a bad fuel pump? It does seem to squirt fuel at the injector like it suppose to. The fuel line seem to be free of any blockage, especially after I clean all the line from the fuel pump up to the injector. Please, please help if you know what I should do or should check next. Thank!
