Re: Volvo Penta 5.0Gxi-B: Two fuel pumps or one?
Don,
I read your other two posts, Don ... I don't see where you got the idea that I was planning on hooking this flow sensor up on the engine(?) I would be hooking it up right at the output of the fuel tank with an Ezy Flow pre-filter - the instructions in the package are clear enough.
The issue that Floscan is warning about has to do with the two fuel pumps (low pressure and high pressure). The low pressure pump cycling causes fluctuating GPH reads, (not total flow) Floscan claims GPH readings are therefore unusable.
"Just hooking the thing up" when Floscan warns about the GPH problem makes returning it to them unused a problem. On the other hand, if other people have done this with a similar set up, and found the GPH fluctuation not to be a problem, then I will 'risk it' and complete the install.
I appreciate your response, but I understand HOW to hook it up. I don't understand whether it is going to work for GPH purposes. If anyone can let me know how it worked in the 'real world' with similar equipment, I would be most thankful. Ed Sanford, Floscan tech support said this was the right instrument, but the package contained this big red addendum to the contrary. Sorry if my previous post was unclear.
-Dale-
