Was off shore the other day and the motor shut down. I checked and the fuel pump was not coming on when the key is in the on position. I bypassed the relay and was able to get the pump to work to get home.
I tested the relay at home with a volt meter and see it is getting 13.8volts, but the relay is not letting power through it. I bought a new relay but still the same problem. all fuses are good.
By chance can the alternator be causing this ?? Or any other ideas ???
Thanks Tim
Thanks Tim
