Volvo penta 5.0
Boaaaaaaattt
I have a 2002 volvo penta 5.0 ogl 4012067821 3869162
Transom is task sx m 3868844 415006287
drive unit is sx 3868891 4202055085
I was floating along my alternator belt broke then my boat shut off I just put a new battery in. I have replaced all my fuses relays and belt iam still not getting fuel any advice
Thanks
alldodge
Howdy
Its a GL-B
See items 33, they are diodes and may have opened up
Happen to have a voltmeter to measure voltages?
Do you know if the pump is running or not?
Measure voltage on the small Yellow/Red wire on the relay while cranking. You should get 12V while cranking, if not trace the wire back to find the diode
