dhardest
- Mar 4, 2017
- 57
My speedometer has been reading zero for a while, and I plan to finally address it. I've read that the pitot tube on the leading edge of the stern drive can get clogged. I've googled it and looked on YouTube and have seen some other model outdrives where compressed air is used to blow the debris out of the tube, but usually there is a joint slight downstream in the tube that is disconnected to give the debris a place to exit, otherwise it just gets pushed further up in the tube. However I haven't found where to disconnect the tube on the SX-A. Can anyone throw me a hint as to where this might be?
