enforcer30
- Aug 10, 2007
- 30
Hi again guys, Still not cured. 96 Volvo 4.3GL runs great accept it will not pull more than 4,000 RPM's after a overheat. The prop and skeg are ok, Compression is 175-180 all six holes, New cap rotor plugs wires and module, Used a external fuel tank and fuel pump to varify check ball anti siphon and it's fuel pump (no change), New fuel water sep., New Carb (it's opening all the way), Pulled the exhaust and found a flap down by the lower unit repaired it and removed the other one (no change), I varified the tach is correct +/- 50, I have played with the base timing (no better than 4K).
What gives, what am I missing????? There is no miss no hesitation it planes alright a little week just will not pull all the way. In neutral I did hit 5K just for a moment. I wasn't about to let it rev there.
Anyone have any more ideas. At this point I would listen to anybody or thing. I appreciate all the help and ideas I got on my last post. Thanks to all.
Once again Thank You, Barry
