bc2planker
- Jul 2, 2021
- 6
I have a 2001 Volvo Penta 4.3GL engine that I am fighting power issues on. It starts and idles fine, but when under load and I power up to WOT, it goes to about 3800rpm, then after 30 seconds or so, rpm and power start to drop to about 3200rpm. Then after another 30 seconds or so, it powers back up to 3800, then the cycle repeats (all without touching the throttle).
Its in a 23' SeaFox, so its a bigger boat for this size of engine, but I can't explain this power cycling. Sometimes it sounds like its missing a cylinder at high RPM.
I have checked and/or replaced the following:
- Fuel pump, lines, filter
- Fuel tank lifter tube and vent
- Spark plugs, wires, cap, rotor
- Ignition coil and module
- Engine timing
- Vacuum (its about 18 at idle)
- Carb rebuild (all new gaskets, etc)
- Engine compression (145-155 across all six)
Any other suggestions on where to go next?
- Engine timing
