Volvo Penta 4.3GL and SX Cobra outdrive service manuals
Perchieboy
Hello Everyone Message:
I have a
1999 Four Winns with a Volvo Penta 4.3GL marine motor ser#TO1314037 and SX Corbra ser#TO826887. I’m looking for service manuals on both of these Volvo products. I have checked with Volvo but my products have fallen off their radar. I believe this was the transition years from OMC to Vovlo.
I just need to identify my motor and out drive with accuracy. I noticed some manuals were for a DP-2 model? Any other letters or numbers within a code to match the serial numbers up while search the web. I just want to make sure I identify the correct product when I purchase the manuals. Or how to you break the serial number code?
Any help would be appreciated from Volvo owners and experienced mechanics. Thank you in advance!
Horigan
Have you tried eBay? That’s where I found my joint venture manuals.
dypcdiver
1999 should not be a Cobra drive (unless very old stock) it is more likely to be VP SX
Mod EDIT: Copyright material removed.
Perchieboy
1999 should not be a Cobra drive (unless very old stock) it is more likely to be VP SX.
In regards to the outdrive, I believe this was the transition years between OMC and Volvo. In the past I owned a 1987 OMC Cobra outdrive. Volvo must have kept the trademark. Thank you dypcdiver for the outdrive manual - do you know what years this manual supports?
Monterey296Twin5.0Gi
bruceb58
It's going to be a BY or a WT depending on what time of year the engine/drive was produced. Look for those two letters in your model number.
If it has Cobra markings, It will be a BY more than likely. BY was the last model year for the Cobra SX
