Volvo Penta 3.0 L GLP-J ticks over fine but has no excelleration- please help
benclegg
Volvo Penta 3.0 GLP-J ser A115602
Had an issue with the fuel pump (completely full of CR**P) and had to replace it, I also fitted a 10micron water separator as there was small amounts of water in the fuel.
No more water but engine runs really badly. Lots of fuel getting to the carbs (if I take off the top screw on the crab, the fuel shoots up a least 2 feet ).
It starts fine and ticks over no issues however when I go to accelerate it dies unless I'm fast enough on bringing t back down to tick-over.
I'm not well up on the Penta engine but have worked on engines before, can anyone help please ?
Ayuh,..... Welcome Aboard,..... I'd bet alota that crap, 'n crud made it all the way to the carb, 'n it's Full of it too,......
Probably oughta pull the carb, tear it down, 'n rebuild it, after ya get the castin's cleaned out real good,....
benclegg
Thanks Bondo, can you help on sourcing a manual or at least a breakdown of how the carb looks. Gives me a better Idea of what I need to do :)
Cheers
tgell001
Is it the demon 2bbl? I had a 2010 GLP-J that I had to rebuild the carb after only 3 seasons. If so, you can find the gasket kit on eBay for almost nothing and you can look up the Holley 2bbl and its almost the same. You can infer the rest. Learn from my mistake and note the orientation of the accelerator pump cam before disassembling or you fight that gremlin and think you rebuilt it wrong.
benclegg
Is this the demon 2bbl? I'm not familiar with boat engines? If I can properly id the ​carb and find a breakdown or shematic ill have a go (with your help of course :))
If you don't mind? ​
benclegg
ok , so I couldn't wait ..................so I stripped it down what a mess!!!!!!
Can I ask is it woth cleaning and a new seal kit? or should I trash the carb?
benclegg
Ok me again......................Can someone tell me what the model number is and where I can get a rebuild kit from ?
tgell001
I've bought two from them (dog ate the first.... yes, really) and they're great.
http://www.ebay.com/itm/REBUILD-KIT-...8d574c&vxp=mtr
If you decided to go new, just buy a holley 2bbl equivalent. They're direct bolt on (only difference is the fuel inlet is on the opposite side, which is an easy mod), cheaper, and parts are easier to come by
Also, a cheap harbor freight sonic cleaner is a great purchase for this job. Fill it with simple green and put all the small parts in it
benclegg
I'm having no luck with this rebuild, either its good on tick over and has a flat spot , or its no flat spot and no acceleration. I'm thinking of replacing it . can anyone please tell me if there is a direct replacement holly carb?
I'm told mine is a demon 2bbl , when I look for holly 2bbl its not quite the same so I've no idea. please help
Ben
benclegg
Me again, Can anyone help ?
Current carb is the demon (with no ser number anywhere)
Production number - 3869388 / TYPE - 3.0 GLP-J / SER NUMBER - A115602 Hull # US-PNYUS7B6H011
I'm really struggling here, is all I need is advise on where I can buy a new replacement or equivalent carb, ive been to both Demon and Holley and to be honest im completely lost
