horse4456
- Aug 26, 2009
- 8
I have a 83 280 that is in a 24' Bayliner with manual steering, the steering binds up. I had to remove the unit to work on the reverse so I figured I'd fix the steering at the same time. I can't seem to get the steering shaft to come loose from the "tiller" I have the cables and linkage all disconnected and the pinch bolt removed but this sucker won't budge. The tiller doesn't look like anything in any of the manuals or parts catalogs so I figure it was a Bayliner set up. There is no set screw only a pinch bolt setup. I started to use an air hammer but I'm afraid I'll ruin the shaft and prying on the transom much harder just seems like asking for trouble. HELP!!!!!!!!!!!!!!
