Volvo Penta 270 help
-=PACO=-
I need some advice on what to do. I have a volvo penta 270 outdrive with the short hub propeller shaft on it. It's mated with a merc 260. My prop is a 15 inch by 19 pitch. I can't judge wide open throttle because it would redline my engine. From what I can tell this is the biggest prop I can fit on that hub. Any one have any suggestions in my need for speed? Thanks,<br />Gerry
Mufasa
Re: Volvo Penta 270 help
There are higher pitch propellers. You can also use the long hub on your drive, you just do not use the spacer @ the prop cone with the long hub.
