Re: Volvo Penta 260 Heads
That depends on the weight of the boat, how far the back of the boat is in the water. Take a piece of clear hose, like 1/4 inch ID, about 10 feet long, and perform a test. With the boat in the water, lean over the side of the boat, put the hose completely under water until the hose is full. Put your finger over one end to keep the water in, and bring that end into the engine compartment. Be sure to leave the other end under water, so the hose stays full. Form a loop inside the boat near the exhaust riser, and let go of the end of the hose. When you do so, the water in the loop should equalize at the same height of the water out side the boat. If the water is taller than the rubber boots attaching the riser to the exhaust Y-pipe, then it will leak if you remove the exhaust riser.
Good luck!
