I'll preface by stating I AM A GREEN-HORN, I am on my second boat, (I bought the first one 2 weeks ago and it wasn't big or fast enough).
I spent $1800 on a 1980 Campion with a Volvo / Penta 120 I/B, the oil smelled like gas (badly), I changed it, checked the plugs, dist., wires, and decided to take the wife and little guys out for a little trip to see how it ran in the best Salmon fishing area in the world!!!
#1 forgot bilge pump (for the last time), and had a ton of water around the motor.
#2 the battery was low to start with, I used the bilge pump to drain, once it was gone I could barely start it, got a boost, and it ran then stopped. Boosted again, with some throttle, had it sputtering but idleing alone, put it in gear, made it out of the marina thouroughly embarrased, and gave it some gas, it stalls. Waited a minute, started it, get moving and it stalls.
My problem, is under any load, it wont run. The carb had a little water sucked in, the dist. was very slightly damp from the bilge f*#k -up, It seemed to idle at home with muffs okay, I was told possibly the fuel pump, bad diapraghm filling the cyl. with gas, that would explain the gas in oil, possibly the stalling, yes????
Looks to me like the folks who sold it knew thier was a problem, tried replacing the plugs, new cap and rotor, and coil.
Anyone who can help, thanks, I will start troubleshooting, just want to know any ideas on where to start.
