I bought an 86 Eliminator with a volvo 290 outdrive. Immediately I noticed that the outdrive would sag fairly quickly if I raised it close to the rubber. On the first test drive I noticed that it would sag to full tilt once under load. It was assessed that I had a bad check valve in the hydraulic pump. I replaced my older model Prestolite pump with an Arco replacement pump that is specifically designed to replace the pump I had. The sagging is gone, but I cannot trim the outdrive up under load. The high and low pressure lines are plumbed correctly from the outdrive to the high and low pressure ports on the pump. So, what is the next step? Do I need to pull the rams, and check the seals? Is there a rebuild kit for the rams on an 86 290 outdrive? Any advice is truly appreciated.
