extrakatana
- Nov 6, 2011
- 7
Have an 88 AQ271 Duo Prop on a houseboat and the tilt/trim works fine throughout the range of travel. However, the tilt creeps down slowly while going forward and I have to re-adjust the trim every several minutes while underway. When backing the tilt creeps upward. The tilt creeps whichever way the thrust is forcing it (it's not holding in place). What is giving way here? the trim reservoir is full of 10W-30 when trim is in the down position...as manual suggests. Do I have hydraulic fluid slow leaking past a seal? What's the fix?
Also, there is a squealing when activating the tilt. I have read on another post this might be from the additional load placed on the alternator when activating, and causing the belt to possibly slip during this brief moment. Wonder if anyone else has a theory or knowledge here.
Thanks in advance
Thanks in advance
