volvo outdrive impellers?
jawzzy
do the 290 DP's have an impeller in them like OMC's 800 and Mercs?<br /><br />While draining the engine and hoses yesterday, I found a big thick main hose coming from the outdrive which led to the pickup holes on the front of the drive. I coudn't put my muffs on, and they're round, and couldn't adjust for the volvo intake positioning, and now I'm wondering if all I had to do was hook water to the intake line I found, that goes to what seems to be an impeller on the main camshaft pully. Any knowledge on this would be appreciated, thanks:)
Don S
Re: volvo outdrive impellers?
No pumps in the drives, all raw water pumps are engine mounted on Volvo's
rodbolt
hello<br /> yes I do it all the time. make sure if there are any oil coolers between the seawater pump intake and the transom that they get witerized as well.
jawzzy
Don: so then I can run the engine with no muffs on the outdrive, as long as I turn the engine off before it overheats? I'd still like to fog the engine correctly. I already spayed the fogging oil in each cyclinder, and down the carb without running it, but not sure that's enough. Also, without running it, I didn't get any of the gas with stablizer in it to the carb. <br /><br />Rodbolt: thanks for the tip, as there is a power steering cooler there, which is why I discovered this water intake line when I was blowing that line out to get all the water out:)
jawzzy
Oh, and thanks for the help guys:)
Dunaruna
Originally posted by jawzzy:<br /> Don: so then I can run the engine with no muffs on the outdrive, as long as I turn the engine off before it overheats?
No, don't run the engine without water. Dons point was that the leg doesn't have a pump - the pump is engine mounted. You still need to connect muffs or connect into that hose you referred to. I know what you mean about a loose fit with the muffs but thats normal - water sprays out from the edges, don't worry. If you run the engine without water you will fry the raw pump impeller in seconds.<br /><br />Aldo
rodbolt
they make a set of muffs specifically for the volvo "swedish" built drives.<br /> buy a set.
jawzzy
Dunaruna, thanks, I wasn't thinking of the impellers in the engine:)<br /><br />rodbolt: thanks for the info, and I'll start looking today!
