volvo out drive removal tool
boston_jake01
I wanted to replace the hose connection in the outdrive that looks like a thermostat housing. I guess I have to remove the a odd looking bolt from the steering helmet it has two allen screws and the threaded holes in the manual it calls for a special tool part # 966868 but i can't find it anywhere is there any way to remove this without that tool?
Don S
Re: volvo out drive removal tool
Just put the screw from the back cover in one of those threaded holes. As it pushes against the gear box it will back that pivot pin out.
Remove the 2 allen screws first
boston_jake01
thanks what back cover do I remove the screws from It is a douprop outdrive I think it's a 290? no markings
Don S
Your cover may look different depending on your model, but you get the idea. On some models, there was only one screw.
boston_jake01
thanks i will try it, i also have to work on the carb it is flooding real bad. rebuilt holley 4 barrel
