O.K., here's what going to happen, I've got a rusty oil pan that is ozzing oil into the bilge, I thought about just smearing J.B. Weld all over the affected areas, but, knowing my luck, that type of patch would most likely fail with the engine runing at 4000 RPM, I've resigned myself to the fact that the engine has to come out, so here's what I think has to happen, pull the 4 front engine bolts, disconnect the fuel lines, undo the battery connections & store the battery, undo the exhaust hose couplings & slide them back, remove the upper/transmission unit from the out drive ( being carefull not to loose the shims )remove the old Bellows, and then remove the bolts that hold the tail end of the bellhousing, ( i've got one of those engine tilters, to be used with the hoist ) also unhook the throttle cable & that squarish electricial plug, and the seawater hose will need to be ubdone, and I'm assuming it should tilt on out, I'm planing to replace the bearings in the bellhousing ... because now it will be easy .... so any words of wisdom would really help me out, this is a 1983 AQ225D engine in a Bayliner CRX223 ( it's one of those Crapri models ... but it's paid for!!! ) did I miss anything?
