can a volvo engine be run with the outdrive removed without overheating or causing damage of any kind? Need to do some carb repair and cleaning and the outdrive is removed for repairs. thanks, mkg this is a 93 model 230A 4 cyl. engine, it has a water resorvior tank on the front of the engine and I assume an impeller in the lower unit as well since there is a water intake hose to the lower unit. Thanks
