Hi,
I own a '06 Fourwinns Vista 278 and have recently replaced the 8.1l VP engine with a 5.7l GXi VP engine. I have stuck with the original XDP-B 1.78:1 drive and F5 prop. During the sea trail the engine could only achieve 2200 rpm and the mechanic suggested it was because the prop was too big. This seems to make sense as the FW 5.7l option came with the F4 prop., although a 1.98:1 ratio. Can anyone suggest what prop size is best for the following combination:
28ft 7000Lbs Cruiser 5.7l GXi 320HP XDP-B 1.78:1 = prop size?
My concern is the 5.7l F4 combo uses a 1:98.1 ratio, not my 1.78:1 ratio....any help would be much appreciated!
Oliver
Oliver
