Re: Volvo D4 225 Trim Tab and Stalling Problems
Hope to find an answer before the warranty expires.
If you were to get your Volvo dealer to actually file a warranty claim on this problem, it will get fixed even if the warranty time does go over. Earlier you said it cost you over $500 and it was a joke. You shouldn't have had to pay anything dude, it's warranty.
Did you ever contact Volvo Customer service directly as I suggested earlier???? If not, why not?
Does water in the bilge cause the malfunctions or are the problems with the actual design of the sensors.
Depends on if the water gets over the sensor, if it does, then the water is also over the starter.......... NOT GOOD. If it is, you have other problems also, like faulty bilge pumps, and a possible leak.
What you really need to do, instead of looking for other people with the problem and what their workaround is, is to put that much effort in contacting Volvo and getting it fixed right.
I did find a service bulletin that shows a change in the trim sender on your transom shield. Your spec number drive is in the early stages of the change and possibly before the change. It would sure be worth having the VP dealer and Volvo reps check it out.
Here is the SB I am referring to.
What model boats did you install the engines in?
I didn't install them in new boats, I installed the D4 and D6 engines with DPH drives in old boats as complete repowers.
My father was in the trucking industy and I have been around diesels forever. Diesels usually run fine if you keep the fuel and air filters clean. I have already changed all three fuel filters three times in 50 hours. I have valvtech bio guard and valvtech diesel guard in the fuel and have added over 120 gallons of fresh Shell diesel to the tank since my last trip to Mexico.
You have a computer controlled electronic diesel in your boat. Your problem has NOTHING to do with fuel or air. You have an electrical/electronic problem.
This ain't no truck.
