Volvo C1.. Where are the zircs for primary
billbayliner
I have the 350 GL with the C1 Dp outdrive. Winterizing and try to find the zirc fittings so I can grease the primary bearing. All I can find around the bell housing area is the zirc for the steering arm.
Any help locating it? I cannot imagine there not being one
Thanks
Bill
Don S
Re: Volvo C1.. Where are the zircs for primary
You probably don't have one. Many of the later models didn't have one.
What is the Engine model number?
billbayliner
Re: Volvo C1.. Where are the zerts for primary
The engine is a 1995 Volvo 5.7 GL PMDA with the C1 DP drive.
BTW Don... Did you get my PM in regards to the air release tool?
Don S
That model didn't have a grease zirk in the housing. The bearing may or may not be a sealed bearing. To grease it if not a sealed bearing, remove the upper gear box, remove the seal, clean out as much of the old grease as possible and use a grease gun with a small diameter tube on the end and pump grease directly into the bearing.
Yes, I got the PM.
