Volvo AQ225 dipstick crossover
Sapper13
Hi,
I just recently acquired a boat that has a Volvo AQ225 (305 V8). It came missing a dipstick. The local Volvo dealer says it’s discontinued. Will a SBC dipstick and tube work from a truck around the same vintage? I can get one of these. The boat is a 1983 Sun Runner bow rider.
Thanks
dubs283
You might get lucky with a truck tube and stick but often they are routed different.
You may be better off buying a used stick that fits the tube, cutting it and marking it yourself
Ayuh,..... Welcome Aboard,.... The odds of a truck dipstick bein' right, is pretty slim,....
If you can find one that's to long, it could be modified to work,.....
I've had good luck, repurposing ole speedo cable, into a dipstick,.....
The drawback is findin' the new proper level mark,....
kenny nunez
If all else fails then try this. Most probably your engine uses 5 quarts of oil. Drain the oil and get a new filter. Put 5 quarts in the engine and get any dipstick that that hits the bottom of the pan, cut and mark the stick where it shows full after starting the engine.
Sapper13
Yeah I think this is route I’ll go. I know the quantity so I’ll go from there. I have a buddy that has a good collection of sbc’s so I’ll see what he has.
