Rankbadyin
- May 9, 2004
- 3
Couple of questions to get a Volvo AQ170 back up and running.<br />1. Installed a used Exhaust manifold that I bought on the internet it appears to be in good condition. It was a bit of a struggle to replace the old with the new,after a struggle, I finally got it in place,when there was this little noise checked out the bilge, and there it was, a frost plug that had popped out of the side next to the engine block. Looks like I have to remove and reinstall the frost plug,and then reinstall the manifold.<br />I am reluctant to reinsall a new frost plug by pounding on it with a hammer,just in case I crack the casting.Can I reinstall the old one using something like J-Weld to hold it place? Or are there other suggestions? <br /><br />2. I was not impressed by the Volvo raw water strainer and replaced it with a better strainer. I cut the 3/4" copper pipes. Can I install a flexable water line or is there a particular reason for Volvo using copper pipe.<br /><br />Thanks in Advance<br /><br />Davie
