fishalope
- Mar 23, 2011
- 16
I just had my AQ131 replaced with a AQ151C. At idle, there is a fairly loud ticking noise that goes away when power is applied. Here is a short video with sound that I took of the noise. I have it paired to a SP-A outdrive if that helps. Also when I took it out to test it on water, It loses power and backfires at around 2-3000 rpm's. Above that it runs great albeit WOT is only at 4400 RPM. In addition, the temperature on the guage shows 200-210 degrees. Thank you in advance.
http://vimeo.com/21263188
