Volvo AQ131D questions
Chris_MI
Hi there,<br />I recently purchased a 18.5 foot 1988 Baretta bowrider with a Volvo Penta AQ131D "rubber band" motor, which is a 120hp 4-cylinder OHC engine that is mated to a Volvo Penta 275 sterndrive. My motor starts real good and seems to run real strong, but I'm noticing two things that get my attention. For one, frequently when I shut the motor off it diesels, or runs on for probably 10-15 seconds. Also, I can only get about 4300 rpm max with 2 people in the boat, and Volvo says I should be able to achieve 5000 rpm. I'm probably overpropped with a 15"x19 pitch SS Michigan Wheel prop. Assuming that my motor is running like it should, this tells me that I should maybe go to a 15"x15 pitch prop, or maybe a 14"x17 pitch prop. I am suspicious of the timing being too far advanced because of the run-on. How do you adjust the timing on this motor? My Haines manual just describes installing a new timing belt and lining up "timing marks". Is that it? No timing light and turning the distributor? I'm not a great mechanic, and I'm trying to make the right moves without buying a collection of props, so any advice you all could lend would be greatly appreciated.<br />Thanks,<br />Chris
Mischief Managed
Re: Volvo AQ131D questions
You would turn the distributor, just like any other distributor equipped engine, to set the ignition timing. <br /><br />Assuming the engine is running correctly, I agree that a 15" pitch prop would be a better choice. You may find that the prop change alone fixes the run-on problem. You are really lugging that engine down with the prop you have and that makes for extremely hot combustion chambers.<br /><br />I have had wonderful results using Chevron Techron fuel additive to get rid of run-on. I can say with 100% certainty that Techron does remove carbon deposits from combustion chambers and intake valves. I have witnessed it myself.
tommays
For that motor to run correctly it requires that the dwell be set correctly on the points AND then the timeing be set with a TIMEING LIGHT<br /><br /><br />Its pickey about eyeballing it :( <br /><br />tommays
Don S
I didn't know Haynes even had marine service manuals, only automotive. You need to order Volvo manual 7732007 from your local VP dealer so you can get your engine setup properly.<br />Here is from the above manual.<br /><br /><br />Setting for regular gasoline, min 91 octane ROT:<br />USA: Ignition setting for regular petrol (RON+MON)/2 = min 87 octane<br />Basic setting .................................................... 6° BTDC (0–14.17 r/s = 0–850 rpm)<br />Stroboscope setting ......................................... 32–36° BTDC (70 r/s = 4200 rpm)<br />Contact gap...................................................... 0.40 mm (0.01575")<br />Dwell angle..................................................... 62±3°
Chris_MI
Thanks for the tips guys. I ordered a 14x17 prop today and I'm gonna try that.<br />Chris
