I hope I am not repeating this. I have a 1986 volvo 4 cyl
It starts good and runs good when not engaged. When I engaged the drive it runs good under 2300 rpm. When i try to increase the speed it chokes and stalls out. I spray some starting fluid into the carb it keeps running but then stalls out. It seems as though its gas starved but only when the drive is engaged. I have rebuilt the down draft carb ($80 for the kit what a rip off) the fuel pump works. There are no restrictions from the tank to the carb. I timed it and put on a new coil, points and plugs. I just can't figure this one out. It runs great in the yard but as soon as I put it under load in the lake it stalls out Any suggestions would be appreciated. Thanks
