IceBreaker
- Jun 21, 2007
- 13
This thing must be haunted!, 1986 bayliner capri, aq131a, 275.
first off it all started when I noticed it hard to start at the begining of the season 2 different times, but it did start, then I put in water ran great went about 5 mi, then it died and hasn't started since but will turn over also lost tilt then bilge pump
since then i have replaced:
Ignition switch twice, funny thing turn key nothing not even a click, turns over when i jiggle the starter relay box but still no start
coil
points set @ 0.16 does this have have a condensor? seems as though it should, if so I don't have one or cannot locate it? ran fine before without one?
fresh gas
starter relay box I think thats what it's called?
fresh battery
in line fuse the big one
under dash 2 fuses
checked wires from ignition front to rear I,S,B..
checked, hit, smacked the big red reset button on engine.
seems as though I'm not getting any spark to the points in fact i'm not.has to be electrical not getting fire from coil to points, seems as though i've exhausted my skills what else is there???
at this point i'm lost not sure what to do from here
I've tried all other suggestions from previous post without success.
can anyone lead me in the right direction. Help!!!
Thanks to all that have been helpfull
Icebreaker
coil
fresh gas
fresh battery
under dash 2 fuses
Icebreaker
