IceBreaker
- Jun 21, 2007
- 13
Well first I'd like to say thanks in advance for any help.
Ok what I have have is a 1986 Bayliner 1650 capri, Volvo penta AQ131A, 275 outdrive. well last year couldn't ask for a better starting engine first hit of the key and away we go, this year I noticed it hard to start, after a long period of time and fussuing with it, it finally started put it in water and ran great without incident no indications of trouble except the hard starting?,
took out of water, put back in 2 weeks later to lay moorn at my dock, same thing hard start but ran great, until I reached my boat dock!! about 5mi away then it just shut down and couldn't get it started, after giving it half a kick of the key it would start but die right off and hasn't started since.
since then I have tried to troubleshoot, I noticed now that the tilt/trim now doesn't work either which did prior to it shutting down? and the engine won't start either? it is getting gas, I checked and cleaned the points checked for loose connections at ignition switch, right now I'm lost. at this point i'm at wits end. any and all advice would be greatly Apprecieated.
Thanks to All
IceBreaker
Thanks to All
IceBreaker
