Volvo AQ130D low compression
neilmw
The story so far......Have a 21ft cabin cruiser fitted with a Volvo 130d which will not go above 3000 revs, have changed points, dist cap, rotor, plugs & leads, engine revs fine out of gear, in forward boggs down at 3000 revs and makes a growling sound, re checked compression (due to faulty tester)and have found that #4 cyl shows 95psi and the other 3 are around 120, could this be my problem and if so any ideas what it might be?
Don S
Re: Volvo AQ130D low compression
No wonder it won't go, the compression should be around 170 to 200. Could be rings or valves. You could do a leakdown test or even adding about a table spoon full of oil to each cylinder and retesting the compression will tell you if it's rings or not.
